OK, I want your opinions about the issue of the new "hybrid" cars. I think they are they are the dumbest fucking thing around. They have proven expensive and also unreliable, having a barrage of problems with the drivetrain.
Now for those of you who know about hybrids and how they work I will keep this brief. when you use a generator to produce electricity you do not get the same amount of energy generated as you put in. (power loss) Next, when you charge batteries with this energy, not all the energy put into the batteries get's stored do to resistance of the battery. (powerloss) Next, you don't get all the energy out of a battery that was stored originally due to internal resistances. (powerloss)
So, by using your engine to generate electricity then store it in batteries to be used later you are less efficient than a direct drive vehicle. (in my opinion) Now I don't honestly think that these highbrids are as great as they are made out to be. Like seriously, these cars are small and lack power. So, I have heard that VW Jetta TDI's and other ultra compacts are getting just as good of milage as these hybrids.
I feel that they have complicated the drive train, making it more unrelible and more expensive to buy and also to work on. I think that the only good thing about these cars is that they are using the generator to apply braking force to the car, in turn, turning wasted energy into stored, usable energy. However using highbrid techology in a conventional car this energy could be used to charge the vehicals battery allowing for the alternator, to supply less of the energy needed.
I have done some research on this and I believe that the an idea was to mount a large diameter electric motor/generator some where between the engine and transmission next to the flywheel/ring gear. This would act as the starter motor for the car as well as the alternator to supply the electrical energy to the car. With this system coupled properly, you could easily use the deceleration force to charge the vehicals battery. we already do this when we down shift in a manual tranmission, but rather than generate electricity you are mearly saving you brakes.
Along with this system, they were also looking to convert the vehicals electrical system to 46 volts to allow for more efficient operation and reduced wire requirments.
So, let me here your thoughts on these issues.
