well the 98 i picked up to replace my 95 legacy that was running out of life and would require more money than i wanted to put into it.( top of the gas tank was leaking, rear subframe needed replacement, needed new regular tires,body rot typical area on subaru's behind the rear wheel well).. since i couldn't find any H6 subaru's in my area at the time i picked up a 98 outback which at the time seemed like a good deal but a few months after i got it, the engine developed a leak at the oil separator plate on the back of the engine which would require pulling the engine and since i didn't have a hoist anymore and paying $700+ to have a $30 plate replaced plus the passenger side axle boot..i randomly started looking for an H6 outback. well i found one and went to look at it during my time off before the 4th of july, without the intention of buying it i ended up walking out that day with the outback becoming mine. stopped in that day with the sole intention of just looking but after seeing it and driving it i couldn't pass it up. it was an insanely clean inside and out 1 owner outback.
the pics from the dealers site before i picked it up..
removed the H6 3.0 badge from the grille
picked up some JDM tails for the outer portion not knowing they were that different from the USDM center part already on my car..needless to say i'm looking for the center portion from someone on this side of the world since everyone from the other side wants insanely high shipping for the center.
did a little de-badging. removed the AWD and H6 3.0 badge from the rear..can't remove the Outback badge since it has mounting pins which leaves holes in the panel
not sure if i want to leave the outback badge off the door or find a way to hide the mounting holes from the badge on the side doors. i like the cleaner look but it leaves behind a couple holes.
slowly swapping out the interior lights for led's started with the door lights.
