I'm trying to determine if I have a problem with the blend door or if this is normal..
When I put defrost ON I get air out the defroster vent, the pillar vents, AND at my feet. A LOT by my feet actually. This is on defrost only, not the split button for feet/defrost.
Normal or not? I feel like its not normal and I want more air on the glass to clear it faster. I'm going to check the vacuum harness to be sure I get good vacuum since that could be a problem, but it has no problem switching to the vents only or feet only. Its just that on Defrost I'm still pumping quite a bit of air to the feet.
Also found out I only have 3 working defrost lines in the rear glass! The joys of a 20 year old car.
