University Discovers how Golf Ball Dimples Work
I saw the mythbusters results when they dimpled a car using clay and the results were remarkable. I wondered if you got a laminate w/ dimples and lined the inside of your intake (CAI) if it would improve airflow. don't have the means to test it though.
(also, waiting for the first dimpled car, the gas mileage would be great, i'd think)
Originally posted by nichols2k View PostI saw the mythbusters results when they dimpled a car using clay and the results were remarkable. I wondered if you got a laminate w/ dimples and lined the inside of your intake (CAI) if it would improve airflow. don't have the means to test it though.
If there can be a specific set of rules to dimpling for flow, then anything requiring such can be improved upon. The pocket just before the valve and/or the valve guide boss for exhaust flow.
I think a dimpled aerofoil under the front bumper could help pull air into the engine bay and promote a greater vacuum under the car.
An entire laminate is a good idea to test. I also think just texturing ahead and during the first 50% of a short side radius turn.
But the texture on the golf ball is 3d. The intake has air flowing in one desired direction, so the dimples can be simple speed dips (like speed bumps on the road) but reversed. That could easily be carved into many intake pipes with a die grinder.1996 Grand Prix | 3100v6 L82 | T04E-50 Turbo | Getrag 282 w/ EP LSD | SPEC-3 Clutch
It works on the flowbench but not like a golfball. The air is moving MUCH faster through the head/valve area and it is different from one area to the next. I bet the depth and distance between dimples varies greatly and would require a super computer to map out every area. Lead dimples effecting the airflow for the dimples behind it. Its not an object traveling through air. Its air traveling inside a box. Now vary that airflow as a pulse with reflections, and you could get even greater impact.
Variable texture runners, only on the 2153 Mercedes S Class.Ben
Originally posted by SappySE107 View PostIt works on the flowbench but not like a golfball. The air is moving MUCH faster through the head/valve area and it is different from one area to the next. I bet the depth and distance between dimples varies greatly and would require a super computer to map out every area. Lead dimples effecting the airflow for the dimples behind it.-60v6's 2nd Jon M.
Originally posted by SappySE107 View PostVariable texture runners, only on the 2153 Mercedes S Class.sigpic"It's your car. Do with it what you wish, but as you enter this unknown world you will need to invent the wheel all over again. For the adventurous and those that are backyard mechanics who have nothing but time you might like this. Most have plenty of frustrating moments and the process usually takes significantly longer then what anyone could imagine. The end result of this conversion is completely up to you." - Jon McCullough of BMCautos.com
Originally posted by SappySE107 View PostDimples, ridges, scaling, its all been done everywhere. I have noticed the top BMW porters have ridges on the face of the valves and in the combustion chambers. Without testing, I wouldn't do any of this though.
I believe progress is a method of knowing all past trials and then conjure something new and test it. 9/10 it is a failed test, but the few ideas that do work are potential gold mines.1996 Grand Prix | 3100v6 L82 | T04E-50 Turbo | Getrag 282 w/ EP LSD | SPEC-3 Clutch
