orderd a wot tech chip sadly it wasnt compatible with my car so ive taken out the chip put the stock one back in i was told to dissconnect the negative terminal to reset the chip i did this while car was running with no change and also tried while key was in the on position....am i doing somthing wrong?
stock chip reset?
You can take the battery out while running and everything will still work.I guess my question is, why didn't the WOT-Tech chip work?
i wish it did work upon placing the chip in my car the speedomiter stop working i also installed a cold air intake that was made for a 88 caviler that had the 2.8 in it upon unplugging my maf the check engine light came on witch threw me off becuase i thought with the chip i would be able to remove this since its switching over to a map and i felt like my car was lacking power...i contacted ben and told him the problem and he was very nice about the whole situation..........i waited months to get the spare money to buy the chip so im really bummed it didnt work but like i said earlier ben was very nice didn't argue or give me trouble when i asked for a refund i would definetly do business with him again
You still have to wire in the IAT sensor when you remove the 87 MAF. It has that built in with the MAF so you can't really remove the MAF without doing this. If Robert can find the VSS code I need for your chip, then the speedo would work. I would at least like for you to test the chip as it should be and let me know if it is worth the price.
It is a 2.8, i just wasn't thinking 2.8 vs 3.1 as I mentally have them both as gen 2 right now:P Too much Gen 3/3500 stuff huh.Ben
i'm getting confilicting info from alldata and my 55/6D definitions.....
is it an optical or magnetic VSS? if it's magnetic, it should be a simple recalibration, if it's an optical, a circuit was briefly discussed in the nAst1 thread to convert the signal the optical makes and make it usable as a magnetic signal for the ECM.
i just dropped it in the mail today.....i felt like i did notice a diffrence but without the speedo it was kinda of hard to really gauge the diffrence but what i paid was a good price and just at the thought of removing the maf made it worth it i reserched several other chips that didnt even mention doing have the stuff ur chip does and i liked that the website was very honest it wasnt claiming to give me 70 horse power or some of the other claims other chips make and i was the guinea pig for celebrity chips when i pick up another car i will probly order another one and send my stock chip for correct tuneing
You will be satisfied when things get worked out. Ben is a great tuner and will work it out if you give him the chance. Luckily I had the two DOHC configurations he needed to make chips for the DOHC, so I got mine for free. Now that he's moved to Florida to expand his business I need to learn tuning in my own so I can tune my cars.-60v6's 2nd Jon M.
Originally posted by robertisaar View Postwell, yes you CAN, due to the alt, but it's not a good idea to do so.-60v6's 2nd Jon M.
