If you own any of the years/makes/models of the 2002 Trailblazer, Bravada or Envoy and you hear a horrendous roaring or jet-engine-taking-off sound from your engine compartment, there is no doubt that your Electro-Viscous Fan Clutch has seized and will need replacing. On the face of it, this would look like a fairly straightforward kind of repair... but plan on busting all your knuckles and inventing new swear words to describe your inability to loosen the single Fan Clutch Nut from its attachment on the water pump take off flange. This flange free-wheels, so in the absence of the superhuman strength required to break that nut loose and the mechanical advantages offered by unavailable Dealership-Style Speciality Tools... I offer another avenue to make this PITA repair as easy as pie!
Please visit my photobucket for all the visual details... I designed the tool in a way that make its functionality obvious so there is no need here for a long explanation on how to construct it beyond saying "measure twice...cut once... and grind down all the sharp edges!" Use either the GM Factory Service Manuals or a Haynes Book for your dis-assembly---re-assembly references... and with this tool...doing this job in a fraction of the time will surely put a smile on your face!
(I suppose that when not needed for this fix ... it can loaned out as the "Snicker-Snee" used by "The Lord High Executioner" in any local production of Gilbert & Sullivan's "The Mikado" from the movie "Topsy-Turvy")
... and for any of the more sentimental among us who know and appreciate the works of G&S...
