I need to pick up some cartridge rolls and was just going to get a whole set. What size mandrel should I look for? The Standard Abrasives set comes with something like 2 3/4" mandrels. I just worry that these won't be able to get far enough into the port. Should I look for at least a 4"? Any opinions?
Help me with buying some porting tools!
i have a MAC tools Die grinder part number AG70 that has a 2 inch long shaft on it. helps get into the ports nice and easy
i use the SA delux porting kits as well.
and then i have my bad boy tool i had made up for plenums... its a 9inch long shank 5/16ths shaft for strength, and the end milled down to 1/4 inch for the die grinder with the same SA porting tool cartrige roll end on it for the rolls.
gets into plenums nicely. it was a one off custom made piece i had done up. only cost me a bit of liquid paymentColin
