has anyone ever had these same problems?? ok this is for my dads '99GTP with the l67, actually has low miles engine bay pretty clean....
the problem is it starts and runs fine for 3-7 seconds the just dies with no codes...it did throw a po403/po405 code (bad EGR), once, but hes also been disconnecting some so idk bout that... other than that it will not throw a code but the TCS light will not turn of.
im leaning more towards the ridiculous TPS sensor failure common to the 3800's or PCM. but the fact that the TCS light wont go off is supposed to mean an emissions related issue.
does anyone have any ideas?
