Front end hardware
  • Front end hardware
    'Does anyone have a diagram on how the front end is set up on a 95 lumina.
    can you be a little more specific as to what you want to see?
      How all the tie rods,ball joint and all else is installed,also car pulls to the right and getting a clunking noise when turning right.Would like to try to adjust the alignment problem till i can get in to the shop for alignment.Also can a moderator mve this to the dohc general section.
