could this motor be easily installed in a s-10?
3.4 dohc
There is probably plenty of room, but you would have to flip the intake around, cut out the portion of the timing chain cover that the P/S pump secures to, fabricate motor mounts and exhaust (unless you used 2 front exhaust manifolds), and then comes wiring. It would be a neat swap though-60v6's 2nd Jon M.
