Several hours today, not bad. From ripping it out to measuring, cutting, welding, leak tests and double checks.
Used a level and carpenters angle device.
Here is the entire exhaust under chassis w/o down pipe.
Here is the catalytic converter. I still need to weld in the O2 Sensor for emissions. Looks like it will pass visual inspections.
Here is the internals to the catalytic converter. The turbo will love this. It isn't just gutted, it's a clean pipe so there is no turbulant edges.
Here is a close up of my welding. Not bad for a gasless flux mig welder.
Tomorrow I will jack up the car, mark off my supports and weld them onto the exhaust pipe. I have raw 1" x 3/4" x 1/8" steel bar for the supports. Will be using rubber between the mounts and the chassis for no rattling.
Will also finish the downpipe if I have the time.
I hope you all enjoy the pics of my progress so far.
