Originally posted by walterdude
View Post
A general oil resistant thread sealer it is.
I have an 11/16" drill bit to tap which is 1/32 smaller then what you recommended. The 1/2 NPT Tap will clear 11/16 in the very beginning. All it means is I will spend a decent amount of time tapping the hole. I know to make 1-2 turns, back it out, clean off the aluminum shavings, re-oil, insert and repeat.
All the while I will be carefully inserting the oil drain adapter every so often to see how far the thread taper is. Since I just learned NPT has a taper in the threads, I will need to check fitting a I tap.
Man, thanks again. That info was very useful.
