Alright, things are coming together. Waiting on a few items, UPS Ground, and 2' of snow isn't helping any, lol. I placed this thread in the Off-Topic section so the topic can swing about.
I still need to figure out how to use my springs in the WasteGate. I have 3 springs. It was shipped with 2 springs which are roughly 2" diameter. One obviously weaker then the other. However, there is one spring that is about 1/2" in diameter. The third spring was installed in the WasteGate. That one was the strongest. The dealer said I can get psi's of 4,5,6,8,9 and 10 psi.
So I actually have 4 springs. One would think the little spring was a mistake, but it is included in the pic from the seller.
LINK in case the pic doesn't load up.
What is that little spring for? I don't want to leave it out if it is needed to function properly. The rest of the WasteGate I figured out. It's pretty straight forward. Now, the little spring has no way to be secured inside the wastegate that I can see.
Also. I read I can safely boost up to 8psi on stock internals. Is that for a low mileage engine? Can an engine with 58k, mild abuse but no neglect handle 8 psi? It will have a tune. Not using the fuel rail pressure boost method for fuel delivery.
