I manage a parts store in Marinette, Wi.... K&N actually makes the R P filters for Royal Purple...so all the info i got on it points to them basically being the same thing. Hope this helps.
And K&N is made by mobil 1 from what I recall... it has a nut welded on the bottom though...
sigpicNew 2010 project (click image)
1994 3100 BERETTA. 200,000+ miles 16.0 1/4 mile when stock. Now ???
Whats wrong with purolator? I thought they were good? I don't get their gold or premium whatever it is though cause of that sand texture surface they spray all the way to the top with over spray on the top and inside...
I don't think I've seen a C version of AC Delco... wonder what C means other than made by wix?
The Purolater PureONE filter is an excellent filter, but there have een some concerns that the filtering media is almost TOO good, and restricts oil flow.
Take it for what it's worth.
Matt
ive been using the napa gold or wix equivalent on the subaru. on the GA ive been using up the pf-52's i bought. bought 2 or 3 of them last time i went and i think i still got one left.
but since the news of the substandard ac delco filters ill be switching to napa gold's or wix. whichever parts store i decide to stop at.
couldnt tell you about the C thing it must be something to do with canada. Eric you live in canada have you ever seen this.
EDIT
ok this is all i could find on the ac delco filters with the C in them.
guess they are polish made for ac delco.
Hey folks. It's been so long since I posted that I can't remember my password . . . changed my email too . . . so I had to register again...
Anyway, I got a case of AC Delco PF47C filters from a Canadian Chevy dealer selling on eBay . . . good price . . . $2 per filter delivered. They are white...
some recently discovered info thanks to Crazy K of w-body.com...
There is a THIRD type of PF52 oil filter. this ones appears to be a VARIATION CHAMPION LABS DESIGN.
the "normal" pf52 is made by WIX and has a strong metal base, with a perforated metal tube in the center.
the "champion labs" pf52 has a "wire cage design" that is made of weak plastic with large holes and is susceptible to failure.
the "new filter" seems similar to the champion labs filter but instead of having the plastic cage, it has a solid plastic tube with holes perforating it, and the holes are M&M sized......
Interesting. Mine has the plastic cage. Which direction does the oil flow? Around the outer edge and through the center?
