I want!!!
  • I want!!!
    Check it out!!!
    New welder from Miller. It only weighs 50lbs and uses single phase 220v (dryer or stove outlet) and has an easy to use control panel to take the guess work out learning a new machine, and you can't beat the price.
    I have seen them for as little as $1272 with free shipping (foot switch is another $140).
    nice and it would be excellent to have
      3/16" max recommended thickness...
        Do you realize the tinsel strength of 3/16" box aluminum/steel has?
        Let me re-iterate : TIG
          I was thinking header tubes to header flanges...
            I've been doing that for years with .030" MIG wire When welding two different thicknesses, you go by the thinnest one since you will be penetrating the thicker piece by only that much...
              Good to know.
                It's a giant!
                  Longcat is LOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOON G!
                  that's WAAAAY too many adjustments for me
                    HOLY SHHH that's a beast... WTF batman!
                      Check it out!!!
                      Do you think it's possible to wire a heavier gauge power cord to it, to get extra distance to the work area? I've got about 3 feet to get through the wall to the back area of my garage, from the dryer outlet.
                        So Force when are you dropping that off at my house
                        99 Grand Am GT
                        1357 cam 227 233 .050 dur
                        515 515 lift 112 lsa
                          Syncrowave 300? What an ancient machine! Does it have an external radiator? The shop I used to work at had one with an external radiator. That was fun to mess with, trying to load it onto a truck to take to the repair shop.
                            Awesome looking welder. Looks expensive
                              quick google search turned up some results in the 1500-2000 range used.
                              99 Grand Am GT
