i put head gasket set on a 3.1 in 96 grand prix now i have a promblem it misefires on #2-4-6-5 can ne one help me i got short push rods on intake.
3.1 misefire
Thats the whole front bank and then some...Check the igintion module wiring. Pull the plugs and see if there wet with coolant, try replacing them and seeing if that works. Did you torque the heads properly and in the correct tightening sequence? Head gaskets are a big job so just make sure all your wiring is in order, try checking the fuel injector harness and connectors at the injectors. Off the top of my head I can only think of the head gaskets being mis aligned maybe (did your engine have the head dowels?) and wrong push rod placement. Just because it's so many cylinders makes it hard to pin point right off1998 Chevy M VIN Mali LS with 99 Olds J VIN 3100 Swap
Sealed power skirted hyperuetectic pistons, LS6 Valve springs, Manley keepers and retainers, Custom short ram, header back, Tuning by Performance Dyno, 3400 TB, MSD Coils and wires, A/C Delete, Gasket matched heads and intake manifolds, 180 hypertech stat, Cat delete, 2 1/2" header back.
