was on highway light came on checked tires 1 was low filled it back now light wont shut off any help pls
97 gtp tire pressure light
i believe they all have to be within i think 3 psi of each other...
if that still doesnt work, consider tire condition, if there is one realy bald and the rest are like new, that will do it... if you have a wheel bearing going out, that will do it...
theres alot of variables, even a wire that is un-done, but then again that would cause the ABS light to come on as would the bearings being bad...
just double check pressures and reset it, theres a button under the dash to reset it...
