2000 la1 camshaft in a 1996 l82 engine
  • 2000 la1 camshaft in a 1996 l82 engine
    hi i am wondering if i can use a 2000 la1 camshaft in a 1996 l82 engine and it will run ok?
    Same exact cam, with the exception of the cam sensor trigger. But, your sensor will still pick up the trigger just fine.
    It says to match trigger to sensor, but its not really required..
      2000 la1 camshaft in a 1996 corsica 3.1M l82
      hi will this cam run ok with my 1996 corsica since the camshaft has a different ring on it for the cam sensor. i'm using a 2000 3.4 la1 block with 3.1 heads and intake and my 3.1 cam is no good but the 3.4 cam is good. thanks
        Yes, you will be fine.
