Well im annoyed frustrated bored and tired of tuning the carberator on my Monte Carlo SS...For the last 3 months ive battled starting driveablity problems and cant get it to idle or rev correctly...The car will not start when cold...usally requires starter fluid. This weekend i took it up to atco raceway and spent 3/4 of night playing with igntion timing a/f ratio settings..best e.t was a 13.7 at 95 mph.Which is HORRIBLE!!!! But still was running funny... The car idle VERY ruffly at 900 rpms but that could be due to the cam specs. But im thinkin its the carberator too...
When normal driving and shifting into second...the car will bog unless your on the gas hard...ligth acceleration sucks....Its not gettin enough fuel above 6000 rpms and to much under 2500...so im wondering if there somthing i can do to correct the carb...or maybe someone can give me some info on a DFI to see if that would make the car more streetable.
The engine has been built for HIGHER reving capablitys. I shift the engine at 7200 rpms. Seem to be the carb i have it for WOT not every day driving. I rarelly race the car it was just a fun street car that i wanted for the average Honda ass kicking. But its gotten so bad i stall more than i race.
Will a Accel DFI system work on this car...any info at all or help on this would be very useful im carberator retarded =(
a lil info on the car.
1986 Monte SS
1974 350 4 bolt main APR main studs Line decked and rehoned deck plates. Pin caps added and complete balenced rotating assembly
understroked 327 scat crank
roller cam lift 539/588 duration 292/300
Vortec ported heads crane roller rockers
TRW 10:1 forged compression pistons
Eagle esp H beam rods
Complete MSD igntion and Edelbrock 750 carb electric choke
World class t-5 (MANUAL TRANS)and zoom dual friction clutch
rear 8.5 housing with Auburn posi and 3:42 richmond gears.
1986 Monte SS
