My car seems to break the torque mounts quite often. Is this a common problem? And is there anyone who sells a polyurethane torque mount for a W body?
Engine Torque Mounts
if you are referring to the dogbone mounts at the top front of the engine, then yes. they also have offset poly mounts, shorter dogbones, spacers, and poly trans mounts. check out zzp.
The largest supplier of aftermarket performance parts for 3800, Ecotec, Sonic/Cruze, and ATS vehicle platforms. We engineer unique parts in house that you won't find anywhere else!
Edit: those are for newer w-bodies, i dont know if they will fit on yours.2000 Impala 3400 with some mods
2005 Trailblazer LS 4.2L Vortec
