CV's can still cause a noise going straight... Why rule out the parts that are under $100 bux and go for ones that take a full day to swap??? Just start with bearing, which you did, then now do the axle and see what happens.
Rule out the simple stuff first... If you havent gotten your wheels balanced do that too... Honestly I can't tell you anything in the trans that will send a high frequency vibration back through the wheel, and last as long as it has... when these start to make noise the blow up rather quickly after.
Also if you still have a receipt, bring back the other bearing and get that replaced, I've heard of very cheap units that fail quickly. Another thing to check is see how much your trans mount is sagging and if your trans case is touching your frame rail yet... if you havent replaced that mount that is definately a possibility.
As for output bearings in the trans there is only one on the passenger side and its a bushing, and if the one on the drivers side went out then you would loose support for your axle and blow out the seal within 5 min of driving, trust me its happened to me, I cooked a bearing and I was on the side of the road in 5 min pouring out B&M trick shift oil all over the road.
