Any ideas on how to improve Vacuum based cruise?
I'm thinking maybe hook it to the vacuum ball, but that might suck it down for the other stuff that runs off of it too fast.
Or maybe give it it's own dedicated vacuum ball?
What do you think? I haven't installed my vacuum gauge yet to see how bad the vacuum drops but on big hills it just stops pulling on the throttle. I wonder if the manifold vacuum drops too much for it to keep pulling, or if it just runs out of cable length (don't think so as I've felt it pull the pedal more at times).
Another thing, any ideas on hooking up the cruise cable to a newer TB that doesn't have the spring return? So that when you go WOT, the cruise cable doesn't bunch up and snag on things? I think the new ones have as swivel and when the TB opens up, the cable slides straight through the end of the swivel outwards... Is that how it works???
If so maybe I could just make a long stiff iron wire that would be like a long loop or rail, that the metal stud off the linkage could slide on ??
Or maybe a ball-chain, but then you run the risk of it bunching up and then tangling or catching something and then the throttle not closing....
Ideas?
Ideas?
