Ok, I've read various methods on the internet about using GM top end cleaner.
Right now I have one can of the liquid stuff and one can of the spray stuff.
On a 3.1l or similar engine, I was thinking about unbolting the upper intake manifold and pouring about 1/6 of a can of liquid cleaner into each cylinder intake in the lower intake, maybe then spray the upper valve stems/seats as best I can in those passages, put the upper back on and then letting the whole thing sit over night. (or should I turn the engine a few times, then let it sit?)
Then crank it up, let it blow out, then change the oil.
Is this a bad idea? I was looking for an "easy" way to get carbon buildup outta an engine (without removing spark plugs, etc.) Thanks.
