umm heres what man said abt the TGP-
The car runs, drives, turbo works but brake light is on (haven't looked into because of head gasket as per below). The car got too hot and blew it's head gasket, I changed the head gasket. It ran and worked well but I didn't fix the root cause (radiator) and blew it again. Now radiator has been rodded, new heater core, battery 1.3 years old, tires less than 1000 miles (H rated 245's).
and i took it for a test drive........... when pressing the gas, the rpm is revving pretty high to around 4500-5000 and the turbo barely hit, like 1 or 2. its not like a STRONG PULL, i mean the car is moving pretty slow but hitting high RPM. i suspect the lower intake gasket BAD?? my friend thinks so too.. so any ideas what it could be? also the brake were acting funny, hard to apply, the harder then all of sudden the tires screeched. could it be related to bad gasket or?
