Rotating the V6 in U-platform minvan
  • Rotating the V6 in U-platform minvan
    I purchased a 2003 Montana ten days ago, which has the LA1 engine. It has been years since I've owned a vehicle with an innovative engine. Looking under the hood I realized the firewall side of the engine was apparently inaccessible for all sort of common maintenance (like changing spark plugs) so I bought the Haynes manual to see what they said. I was astonished to read about "rotating" the engine by releasing torque struts, tying onto the engine with a strap wrench, and literally rotating it forward.
    I'm stumped. The directions are clear but in a larger sense I can't picture how this works. What is the basic concept in the engine mounting that makes this rotation possible? Also, I don't understand how the exhaust system could have been designed to accommodate this rotation.
    Yep that is how you do it in quite a few fwd cars. Take out the front 2 upper motor mounts and let the car move forward in park. The motor will rotate forward enough to work on it. You will not damage anything in the process.
      The exhaust has a pivot point in it. There is a flange on the down pipe, and a donut gasket on the exhaust manifold. The flange is held to the exhaust manifold by springs held down by 2 bolts so that the flange makes contact the whole time the engine is being rotated.
