Can someone explain how this works?
  • Can someone explain how this works?
    http://cgi.ebay.com/ebaymotors/ws/eB...MEWA:IT&ih=017
    I don't get it, the car is going to run horribly without the IAC, TPS, IAT, or EGR.
    It seems like a tool for dealers that didn't want to buy a scan tool.
    1992 Lumina Z34 | 3.4L 207ci DOHC 60º V6; Getrag 284 |
    1994 Pontiac Grand Prix GTP | 3.4L 207ci DOHC 60º V6; Hydra-Matic 4T60E |
    IAC doesn't matter because you adjust the air with the plate. MAP is set with a vacuum pump (says in the directions).
    It is used to check that everything is working before you put the upper intake back on after a timing change. Has nothing to do with a scan tool.
      Ohh ok. The seller said its to check the injectors while the engine is running. I figured why they hell would you need to do that if you have a scan tool. Granted back in the early 90's scan tools were probably a new thing.
        Woops
