what would happen if you tried to split your exhaust in two starting at the downpipe...pretty much after the flange... i mean cut the downpipe to a tri-angulated tip, and then welded up you two pipes to it? (using 3100 and 3400 engines for scenario)
first and foremost im thinking oxygen sensor issues... obviously theres one stock downstream, not to mention even if there was two downstream there would still only be one upstream.
Now you could make it without being emmisions compliant easily, but it would be more interesting to try to use brains to over-come OBD2 problems... 02 sims? parralell circuits with some kind of voltage altering resistors?
im not so sure that even if you could work it out it would be benificial... i mean, the exhaust manifolds are still the same size, it's not like thats different... but i guess im wondering how much faster they could dump out into a dual pipe set-up. humor me, i am an automotive slut, i'll concider anything.
