Vtec Just Kicked In Yo!
  • Vtec Just Kicked In Yo!
    >_>
    Does anyone else besides me think this is fake? The creator claims it's a stock civic I believe, yet for some reason I'm not buying this.
    And it's KPH, not MPH, for those who haven't noticed :P
    civics can rev up that high.
    but they can't move that quick i could'nt hear the sound.
    but judgeing by how quicked it moved i can assumed the engine is from a gsr...
    1992 nissan maxima se (190hp/205tQ)
      maybe the engine / tranny swapped is causing the tach/ speedo to read incorrectly?
      lol i like the missed 3rd gear.
      got zap-straps?
      89 Z24
      13.886 @ 96.16 mph
      street trim - slicks
        I think his gauges are whacked. Look at the tach right at startup. It is reading an idle speed of 1500 to 2000 RPM. The engine sound is not that of 1500 to 2000 RPM.
        Then as he revs to 9000+ RPM, the pitch of the engine does not sound like an engine at 9000 RPM. It doesn't sound bad, just not 9000 RPM.
        My opinion (just an opinion) is that his car is fast but gauges are not working properly.
        David Allen - Northport, AL
          yea i think your right cause the tach kept going past 9k.
          when i had my accord and revved to 8k it did'nt sound as if you would expect a engine revved to 8k would sound.
          same as my acura legend.
          but my nissan ve? it's loud as hell when revved to 8k.
            Yeah doesn't seem that fast despite what the gauges show, and the revving business is silly. Even for a s2000 engine or something. If you figure it's KPH it's not that impressive. Something doesn't add up.
              Another thing that speedo is in kilometers. but still look at the back ground at the end of the clip the speedo shows 160 but it doesn't even look like highway speeds. 160 kph=99mph
              68 El camino 454 speed muncie 3.90 posi 12 bolt,
              80 Monza Spyder nasty buick 231/3.8l v6 200-4R 3.73 posi.
              60 Impala 2 door hardtop L79-327 T56 4.11 posi.
              83 wagoneer torque pig AMC 360 hydradrive (gm turbo 400 with stock sb chrysler bellhousing boltpattern) dana 20 transfer case dana 60 front GM 14 bolt rear. 401 in the wokrs
              91 Z34 now has a hm284. and belly pan in the works
                Also, something I noticed...
                At 3000rpm he's at 30kmph, 4000rpm he's at 40kmph, but at 9500rpm he's at 75kmph...doesn't seem to add up...
                  if your implying his gauge cluster is electronically controlled like most gm's...it's not.
                  i'm trying to remember if you could see him driving..if so then it could be possible.
                  a gsr engine is capable of revving that high...why becuase it's a small engine so it makes most of it's h/p there
                    No, I'm implying that speed isn't matching RPMs
                      sounds like he has a VTACH, Not a VTECH
                      Brian
                      3400 SFI V6, 4T60e
                        he should have got the gauge to let him know when vtach kicked in.
                        and yeah im serious autometer does have a gauge that tells you when vtech kicked in
                        99 Grand Am GT
                        1357 cam 227 233 .050 dur
                        515 515 lift 112 lsa
                          I still need to make my 60*tec video.
                          Stock 1995 beretta, 2 jackstands, video camera, and some editing. Il post it as a response to his vid.
                          95 Beretta- Lg8 Daily Driver
                            Could have been On Blocks
                            Could Have Been On Blocks?
