60DegreeV6 Clean Diesel Engine
  • 60DegreeV6 Clean Diesel Engine
    General Motors has debuted a new 2.9-liter V6 turbo-diesel engine, destined to find its way into the 2009 Cadillac CTS.
    The V-6 engine management system enables optimal fuel economy as well as reduced emissions and noise by using a recently developed combustion control technology. Key enablers of the system are high-speed, piezo-resistive cylinder pressure sensors that are integrated within the engine glow plugs. These specialized sensors acquire real-time data from the combustion process, enabling instantaneous fine-tuning of the fuel injection process. In the future, this clean combustion control technology will be introduced in other GM Powertrain diesel engines.
    The high-pressure, common-rail system provides up to 2000 bar (29,000 psi) injection pressure. The injectors are quick-firing, piezo-electrically actuated, allowing up to eight injections per engine cycle. The aftertreatment system includes an oxidation catalyst and a particulate filter that are close-coupled to the engine to achieve future emissions standards.
    An electronically controlled variable geometry turbocharger generates boost pressure. The engine has a torque of 550 Nm (406 lb.-ft.) beginning at 2000 rpm, while providing effective fuel economy and reduced emissions.
    Yup, I know this was posted before. Josh has to swap this into his vw.
      Look at that Alt... Reminds me of the tdc 3.4's.
        It's externally balanced.. strange.
          Yes, it was posted here on 03-06-2007, 12:13 PM, but I wasn't on forum then.
          GM diesels are coming, btw....its the future.
            How so? A number of engines are externally balanced.
            Your local OBDII moderator
            2000 Grand Am GT w/ WOT parts
              especially diesel engines..
              [SIGPIC]
              12.268@117... 11's to come!
                Hmmm Future swap for my new Trooper. The only way that would be possible is if GM makes a standalone ECM or if someone hacks the stock one really well.
