Walbro installation problem
  • Walbro installation problem
    Hello all
    I am in the process of installing my walbro fuel pump in my 1999 malibu and am having a problem as to how to attach everything using the T fitting and the red plastic fuel line that comes oem to the pump. When i use the zzp kit to install it the fitting off of the T does not fit the red line so I have opted not to use it. When I use the fuel line supplied in the kit i find that it kinks. I tried the step by step by TeJohnson but I cant see how he actually got the red line to attach to both the T and the top of the pump. Any help from you n-body folks would be totally awesome.
    Was i supposed to buy the 3800 specific kit or was i led in the wrong direction? Carless until helped :P.
    Colin
    answer to this is...
    if you have an N body DONT get the 3800 specific kit like others have stated.
      you got the 340, they used to sell the 255 under the 3800's
        it is a 255.
          you told me 340 in a pm on mc...
            UNLESS you have a 99 Grand Am.
            Your local OBDII moderator
            2000 Grand Am GT w/ WOT parts
              1999 malibu and grand am have the same part numbers for the fuel tank and system man....
