Drove my car to class and back Friday, didn't touch it the rest of the day.
Today went out and took out the bulbs in the rear left taillight and all of the bolts, I wanted to get the housing out to reseal it since it leaks a bit. I pulled and pulled and finally discovered someone had attached the whole housing to the car with silicone, so I said screw it for now and pushed it back in and bolted her up. I knew I had a reverse bulb and brake light bulb out, so I pull the burnt bulb (reverse) and put all of the rest back in. Check the brakes, lights work fine. Running lights, fine too. I turn on the blinker... nothing.
Turn the blinker on the other way... nothing. WTF? I hit the flashers, they work fine, all bulbs lighting up in front and back.
So I wonder around a bit, check the blinker fuse and it's fine. Replace it, still no worky. I put my multimeter to where the blinker fuse goes and I get 12v. So I figure OK it's the flasher module thingy under the dash.
Replace it, still no blinks. What the HELL? Pull the flasher back off and turn the blinker on (with ignition on) and get the multimeter on it, no voltage no matter what I do at the flasher.
Replaced the reverse bulb, tested ALL bulbs on the car. ALL work.
Leads me to believe it's the switch in the stalk, but it doesn't matter how much I play around with the stalk I can't get any blinker action. It worked perfectly fine just earlier.
Help me! I need to go start tuning but now I have no blinkers!
