seafoam
  • seafoam
    what is this stuff just sea foam? i heard of people putting it in there gas tanks and vac lines what dose it do?
    Ford Guy says to we " keeping up with that General Maintenance as you drive a gm?' I say to him well when you found on road dead tomorrow, I'll be in the next province.
    It will clean the hair off a chinchilla great stuff.
      In fuel or intake it works wonders dissolving carbon deposits in heads. Helps get rid of intake valve buildup, and combustion chamber crud that leads to preignition.
      Also helps free up gummed/ varnished oilpump pressure valves and hydraulic lifters when used in the oil.
      Just my two cents worth, I use the "deep creep" aerosol sea-foam at work and it is good.
      David Allen - Northport, AL
