are the 3 old cats that I have seting in my garage worth any more than there old iron
are old cats worth anything
sometimes around $100 or more each...Originally posted by MATT2007 View Postare the 3 old cats that I have seting in my garage worth any more than there old iron
Call around to salvage yards and see if they can give you a lead on a place to sell them to.
GM cats are usually worth $10-20 when I sold off mine.Brian
3400 SFI V6, 4T60e
i have 4 late OBD2 cats and 2 of the huge early pellet cats, as well as 2 others. i've heard anything from $20-$80 depending on the cat from a reputable salvage yard. the arseholes here are the only place in town and offered $3 each... no way.
what are alloy wheels usually worth? I thought they go for around $10 each, but I had a set of chrome ones I sent off, I got like $2.50 for four. I think I got jacked.Brian
3400 SFI V6, 4T60e
Usually ALLOY Wheels go for 2-3 dollars each if it is without tire, without valve stem, no wheel weights, and atleast 14"-16" Anything bigger is maybe a dollar more. It is not number one alloy so it is worth less than if you took in something that was number one grade. If it was number one grade you'd probably get $6-10$.
.02Lifting my front wheels, one jack at a time.
If they are pellet or waffer ceramic they are worth 10-15 dollars a pound of ceramic waffer or pellet. Waffer has more catylst therefore worth more. Can be melted to recycle platinum and in the end about a half ounce can be procured from 10 pounds of pellet, 5 pounds of waffer.I am back
Mechanical/Service Technican
