whats up peeps....i keep getting code P0401 setting....it says (EGR SYSTEM FLOW INSUFFICIENT)....i have taken the egr valve off...cleaned it best i can..and still have this issue....could it be bad and set this code? and not set some other type of code?...now for a little background info....it's on a 96 pontiac grand prix se...3100 sfi motor...i recently had some tranny work done...and i have had to replace the thermostat...that was a bear to do (had to do alot to get to thermostat)...one thing i noticed for a long time....my egr valve pipe had a small hole...that means a small exhaust leak...when ever i needed to move that pipe the sound got louder...so i pulled a pipe from a car at the junk yard...it works and i have quiet exhaust....could that hole i had for a long time have made something worse?....anyway there is something to think about for you all
...peaceeeeeeeeeeeeeeee
