easiest way to change an o2? pull engine forward? or get to it from underneath?
o2 sensors
Take off the coil packs and bracket to give you more room. IIRC when I did it in my beretta I just got an O2 socket, and some extensions and a breaker bar. I think I sprayed WD-40/PB blaster the night before. Not sure how good that is for the new O2 when you start it up it will smoke a lot... Get to it from the top. Impossible from bottom..
My car I have a side engine mount and can pull the engine forward and hold it there. I think you have dogbone mounts but might have more room since it's a bigger car.sigpicNew 2010 project (click image)
