Alright, another 'extreme' case of customer negligence . . . customer brings in his Bronco looking to have the brakes checked out. Complaining that it takes a while for the vehicle to stop. He also mentioned that it was making a grinding noise a long time ago, but the noise went away and the vehicle stops, so . . .
Anyways, check out what we found:
Like that rotor, huh? Caliper was seized, also. Well, what "COULD'VE" been fixed with probably just cutting the rotors and installing some pads (before it ever started going metal to metal), turned into a massive repair bill consisting of new rotors, pads, calipers, brake hoses, front bearings and seals, 4x4 hubs (toasted them, too), and the LF aluminum factory wheel had to be replaced (what was left of the rotor had rubbed a small pinhole in the inside of the wheel, it was leaking air); For the rear: new brake shoes and cut drums (heat glazed, and cracked from being overworked), new brake hardware, and new wheel cylinders. I also recommended replacing the master cylinder and the rear brake hose (might as well), but the customer didn't want to spend that little extra.
So, the moral of this story: HAVE YOUR SHIT CHECKED OUT REGULARLY!!!
