3 hours of work, and car was already jacked up, and the front manifold and crossover were already off, and I didn't get the rear manifold out of the POS car. 3 hours and I got 8 fucking bolts!!! Goddamn I have said so many words not safe for children it isn't even funny!
I got the spring bolts from rear manifold to downpipe no problem(*blesses the Getrag for having room under the car*)
But then the 6 studded nuts. Oh my Fucking God. The bottom 3 were kinda easy, just not much room to spin the ratchet. But I got them. Now for the top 3. Yes! The alternator gets inthe way of Cylinder 1's top bolt. Cyl 3's top bolt was easiest. But then Cyl 5's. WTF??? It is BEHIND the rear manifold. OMG what a terrible design. I finally got it, getting it from above! That SUCKED!!! Do not attempt without beer, A LOT OF BEER. I now I have to remove the studs, which will be tough, but they shouldn't be too bad because they aren't oblong. The nuts are, they aren't perfect circles, they are ablonged, so upon removal, they get tight, loose, tight, loose, tight loose. AND IT SUCKS.
*Done venting*
*Done venting*
