domecitc x..tuner, something different..!!
  • domecitc x..tuner, something different..!!
    hey good peeps my first time here , yes a newbie, but i do know about customizing...here are sum pics more on cardomian.com..94 olds acheiva sc with engine swap to a 3400...check out the beginning to present on cardomain, member name is sealtrix and/or domectic experimental tuner..
    nitrous acheiva
    Just wondering why the bottle faces to the right the valve needs to face forward at an incline do to the tube inside.
      you are correct , but the bottle is angled and it's easily accesible with my right hand...
        I would like to see a pictrure of your hood. from the front. Is that functional? are you playing with the olds because it's all you got or are you an olds nut?
          hey sleeper i'll show you a pics of hood, they are actually hood scoops but the underside is cut so air comes thru hood at least to disapate sum heat from engine
