The White Whale's Replacement
  • The White Whale's Replacement
    THE RED LOBSTER!!!!
    This Lobster of a car is my new...car. Now before I hear it about the damn transmission I just want to say that like the Whale, the same critiria applies. I wanted a car with the sport package, ABS and halfway decent paint. Engine and transmission is neither hear nor there. Overall its not too bad of a vehicle for $200..... Needs a cam carrier with cams, the front intake cam seized up, the rear brake lines are leaking, rear struts are all but gone, the subframe is missing a bushing, the interior smells like moth balls, seems that squirells moved in at one point as this car hasn't moved in the last 4 years, it does have the full radio and a Hud!. WHOOPIE......I have the super daunting task of making this Lobster sea worthy and complete like the whale was. Body and Mechnically, the Whale was infintely better, granted I didn't get it like that but it turned out pretty good. I just hope I can get this car to turn out as well The only this that really annoys me about this car is the driver door. Looks like it was over extended and the door check mount is messed up and the hinges also look over extened too. Fog lights are busted too. I plan to roll with the TDC for alittle while so I can pass emmisions, and then I'll go back to the 3400. I can only hope it holds together, I'm not long on the condiitons of the engine and the compartment. I'm not going to run with the Auto but I'm going to keep it stored just in case this gearbox has a problem. Anyways tearing down the Whale I now know why I spun out, My right rear tire is worn pretty bad. Its almost a slick....If I drove over any water that probably woud've done it. Anyways I picked the car up in Massachusettes and I Uhauled it 200 miiles back to LongIsland. Total trip expenses including the car was $700. I might run with the whale's white wheels. Anyways I want to thank those that supported me after my accident. Thank you.
    Lorenzo
    omg, it looked great till you showed me the motor. Poor LQ1. Looks a bit uneven too but I guess you are gonna be spending some time fixing it all back up.
    Ill give you a motor/trans for your trans:P
      I think my power antenna is broken....the hud dosen't work...the keyless entry is not working either... it really smells in there...The engine is falling down....
      Lorenzo
        Now that I see the engine, I'll throw in another piece in the package. The plastic beauty cover for the fuel rail. We will have this Lobster with butter before too long. Is the left front engine mount trashed? Got 1!
        I'll give you Bens' engine and tranny for your tranny! :P
          well I was finally able to drive the car last night. The Lobster clawed and snapped it's way out of the back yard and onto the road way. This car hasn't driven in 4 years and I thought it was going to be a big pile, esspecially since I tore the whole interior apart, and the front end was literally a nightmare... But I have to say its got it's stuff together. Cruise works as does the A/C. The engine is doing its thing but it has a high idle issue, I'm sure the intake gaskets need replacing. The transmission is in fantastic shape as is the clutch. Was it worth the 3 weeks of work? Maybe.... The car is a hoot to drive, but I'm troubled by that damn parking brake. That really needs to be a handle. In a standard shift car, that pedal is really out of place and awkward...My 3400 would be very nice to have in that car. The body has some issues but I think if I keep at it this car will be a keeper. I'll get some more pics later.
          Parts Xfered from the Whale-
          All interior sans the headliner, sun visors, lower dash covers, upper dash pad
          Automatic day night rearview mirror
          Rear brake calipers with stainless steel sliders
          Drivers side parking brake cable
          Moog rear spring tip helpers
          Trunk weather strip
          Driver's side tail light
          Wiper arms
          Cowl and revel moulding
          PepBoys Prostop ceramic front brake pads
          '97 Lumina Police Package front Stuts with big brake rotors
          Ball joints and Tie Rod ends(maintenance free)
          Front wheel hubs
          Front ABS Sensors
          Front stabilzer bar
          Die hard Gold Battery
          Battery terminals
          pasenger side fender upper trim
          Pioneer Speakers, and Radio
          C piller panel with lights
          Aftermarket Power Antenna
          Door locks, trunk lock and ignition lock
          Gas tank cap
          Center car wiring harness for Systems Monitor
          Turn signal switch
          Turn signal lever
          Electronic flasher relays
          Steering wheel with satellite control and cancel cam
          Truck trim
          Gabriel Rear Strut Bumper/Bellows
          2 rear subrame bushings
          1 front subframe bushing
          Hood cable
          Door Panels modified to fit door speakers and covers(Thanks Dad!)
          Parts Bought New-
          Fittings and unions for rear brake lines
          Fitting for front passenger brake line
          Rear KYB GR-2 struts with KYB mounts
          3 subframe nuts
          Raybestos PG plus rear brake pads
          Door lock actuator
          Electrical conduit for various wires
          New 3.1 Alternator gutted and parts placed into TDC housing
          Lower pass side heater pipe replaced with heater hose
          Intake manifold and EGR gaskets
          Coolant temperature sensor(computer)
          '00 Mini starter
          Need to replace-
          Keyless entry box with plug harness
          Driver door
          Driver fender
          Driver Lower fender/door ground effect trim
          Passegner side Head light panel
          Future plans-
          3400
          Window tint
          The White Whale's white wheels
          Wider tires
          Alarm
          Fog lignts
          And I want to thank RBC for the TDC parts! Thanks!!
          The only thing I really want to do right now is change the fuel filter but it's frozen on. Any ideas on how to free it up?THX
          Lorenzo
            No problem on the parts. Glad they went to a good cause.
            Fuel filter: I've found a torch to work very quickly! :P
            (Soak it in penetrating oil for a few days)
