New to posting, but been reading for a while. I bought a low mileage 84 Vette with a blown head gasket. Body has no rust. Dents and dings that match it's age. Anyway since I've acquired my Vette I've been reading up on this forum and decided the best swap for the 1.6 Chevette is the 3.4. I'm in the parts collection phase right now. I got a 94 Camaro engine doner a friend gave me. The Camaro engine is freshly rebuilt with a mild cam not sure of brand or specs. I may have to put my dial indicator on it and measure it. I've also collected a complete 3500 from a 06 G6 with 85K miles on it. I plan to use the heads and intake off of. from what I understand that combination will net around 11.5:1 compression ratio and may be ok on 93 octane if the cam has enough overlap. If not that's ok cause it's not a daily driver. I can run racing fuel if i need to. Will running 100 Octane Low Lead aviation fuel foul the O2 sensor? There's a ton of info on this forum. I still need injectors, throttle body, a Camaro T-5, and peddle assembly from a manual Vette, ect. Not sure what computer to use. It would be nice if there was a sticky that layed out all of the RWD 3.4 / 3X00 hybrid good guy parts / process. I'll post updates. I figure this will be at least a year long project
Hybrid 3.4 / 3500 Chevette Project Western MD
