'96 Century general project thread
    replied
    w-bodies are similar in that they also bolt directly to the control arm. that looks like the bottom side of the control arm though?
  • Purple pit
    replied
    Wild, almost looks like a rear bar.
  • LeftVentricle
    replied
    No. End brackets bolt directly to the control arms. Phone posting right now. I'll post a picture later.
    EDIT: Click for larger.
  • Purple pit
    replied
    Guessing that you don't have end links on these cars.
  • LeftVentricle
    replied
    Not sure what is going on with the sway. Some sort of change between the years?
    I don't rightly know either. You may be right. The white wagon is a '96, while the yellow sedan is a '92, and I got the bar from a '96. I don't really see GM changing the positioning of the sway bar mounting studs for no reason. I think the control arms are even shared between car and van. But no big deal. The stock one bolted back in.
  • Purple pit
    replied
    Going to say that the van springs will raise the front a bit too much. The only other thing you can do with springs is have a spring shop test the stock ones. Then they can try and make some replacements or a bit stiffer springs(if later you would like to have the APV rears). The brake upgrade would be a great idea as newer cars have much better brakes and stop much shorter.
  • LeftVentricle
    replied
    Installing the U-body van sway bar on my '92 sedan ended up being a bust. I spent the better part of three hours fighting it, and ended up just throwing the stock bar back in. The bar-to-control-arm brackets just would not line up with the studs on the arms. I would get one side loosely bolted on, then the other would be 3/4" off. It wasn't a problem at all when I did the swap on this white wagon. I'm left scratching my head a little here.
    As for the van brakes, there is a laundry list of parts that one has to acquire. The majority of them can be bought new, but the steering knuckle, as far as I can tell, is NLA, so you have to get it from a 92-96 van at a junkyard. The brake components (pad, rotor, caliper) you buy new, specifying for the van. You can even get drilled and slotted rotors and carbon-ceramic pads if you want! Then you have to use van ball joints, tie rod ends, and rubber brake lines, since the stock car lines are about 5/8" too short. The hub must be used from the A-body car. Then it's just a matter of screwing everything together. Once you do though, you won't be able to use your stock 14" wheels anymore. You will have to move up to 15" at minimum.
    According to most sources I've found, the U-body van shares its front brakes with the C, E, F, G, H, and K platform cars. Year ranges vary, but it's generally mid-90s.
    Then there's the van struts. Someone over at a-body.net found that the van strut is the same physical size as the one for the car, but the damping is much stiffer, since the van that weighs something like 500 pounds more. Then you just bolt on the spring and mount from the car, and slap the whole thing back in to place. Using the van spring will raise the front of the car a bit, but I'm not sure how much.
    You can also use Lumina APV cargo van rear springs if you wanna stiffen up the rear. I don't plan on doing that anytime soon though.
  • Purple pit
    replied
    Was thinking that the Le Sabre strut tower bar would fit. Sounds like that is a no. On the bushings they were universal , links were on the shelf at Advance Auto and the frame to bar was from Summit(just had to find out the size in mm).
    Wow 3.73 is a bit much. Looks like you have the cruise RPM about right with the 3.33.
  • LeftVentricle
    replied
    I'm happy with my 3.33FDR, but kind of wish I'd gone for the 3.43FDR(oh well).
    I've gone the other way, having a 3.33 re-chained to 3.73 in my old Celebrity, and I ended up not liking it. Even with the old 2.8 doing only 98 hp at the wheels, it would burnout quite easily, but my highway fuel economy suffered greatly. I went from a consistent 29-30 mpg down to 25-26, both at 65 mph. With a 3.33 and 25.5 inch tires, the engine will be spinning right at 2000 rpm at 65 mph, right in what I would consider the "sweet spot" for a 3500 with a torque cam.
    Can tell you that poly bushings on the sway do help, took years to just up and do it. No regrets and just a few head smacks for not doing it sooner.
    Would you happen to remember where you got poly bushings? I'm having trouble even finding regular rubber bushings for the bracket that bolts to the control arm for the '96 van bar I picked up. I can get some for the Century, but they apparently don't even exist for the Trans Sport.
    Is there a strut tower bar that works from another car?
    Not really. Someone over at a-body.net modified one of the C/H platform bars, but to my knowledge there isn't one specifically for the A-body.
  • Purple pit
    replied
    For sure going to watching close now. Like the swap and also like small upgrades to make it a little better. It's much like the work that I've done and still have to do on my car. I'm happy with my 3.33FDR, but kind of wish I'd gone for the 3.43FDR(oh well).
    Can tell you that poly bushings on the sway do help, took years to just up and do it. No regrets and just a few head smacks for not doing it sooner. Is there a strut tower bar that works from another car?
  • LeftVentricle
    replied
    Eventually, yes. I plan on doing some more stuff tomorrow, and will make a post.
    There is an upgrade path for these cars, believe it or not. Setting aside the obvious LX9 swap, suspension, steering and brake parts from the U platform vans bolt on without modification. I've already done one of what I like to call the Big Three, which is the van front sway bar, on the white wagon, but I picked up another bar yesterday at the yard, and will be installing it on the yellow sedan seen in my sig. I will document the swap here. It's not difficult at all.
    Other plans for this car include the aforementioned LX9 swap with some WOT-Tech goodies, like a torque cam and ported top end, a 3.33 transmission from Triple Edge to replace the stock 2.97, and a tuneable 1997 computer from Milzy.
  • Purple pit
    replied
    This is a good why not topic, so you know I'll be reading and watching. There will be more to come right?
  • LeftVentricle
    started a topic '96 Century general project thread
    Hey all. I figure it's probably time I start a proper project thread for my 1996 Buick Century Special wagon. I've done lots of things to it over the nearly three years I've owned the car, not all of which I have documented here. So I'll start at the beginning. As always, you may click on any image to enlarge it.
    February 28, 2013, I brought the car home, and immediately put it to work, assisting in moving from a small apartment to, for the first time in my children's lives, a house, with four bedrooms, a back yard, and a two car garage. Here is George with some new dressers.
    Five days later, the thermostat stuck closed and blew the upper radiator hose, which, in turn, popped the head gaskets.
    I spent the next ~5 months rebuilding the top end. You can find the thread here.
    Not long after, the rear brakes fell apart. I guess they didn't like having the parking brake engaged the entire time I was fixing the engine!
    Then, the transmission decided it would no longer shift out of park properly. If I put it in park, it would engage the pawl, but shifting out of park would engage the gear but leave the pawl stuck in place, so the car would not move! The only way to get it unstuck was to shift to neutral and rock the car back and forth until it popped free. It would also do that if I tried to shift from forward to reverse, so I essentially couldn't use reverse. Rather than do that every time, I just left it in neutral, set the parking brake, shut the engine off, yanked the key out of the worn-out ignition, and locked it up. If I wanted to go backward, I would have to push it myself.
    In March 2014 I picked up a junkyard transmission from a place in southern California, which was the closest I could find one. One thing people don't tell you about the '96 cars is that lots and lots of parts are one-year-only on them, including the transmission. It took me a couple months to save up the money for the fluid, filter, torque converter, and mounts needed to do the swap, but I did it over the course of a few days during Memorial Day weekend that year, with a little help from a couple friends and my dad.
    Here is a link to an album of all the pictures taken during the job. (I'm lazy and don't want to do all the markup for 130+ images at once.) (imgur is being shitty at the moment. will add a link later.) Now I could reverse again!
    Once that was done, I took it out to the drag strip to see what was what. It wasn't that great. I ran something like 18.34 @ 75 mph in the 1/4 mile, which is rather embarrassing, frankly. Me on the return road after racing a friend in his HHR, which ran 17.99.
    Video of our race (boring):
    After that, things ran fairly smoothly. My legal courier job kept me quite busy, especially around Christmas when I had to pick up well over two hundred "gifts" from one of my clients to distribute to their clients.
    I also don't know how to properly install shocks.
    January 31, 2015 saw the procurement of 15 inch steel wheels and extra load tires, along with Cadillac Deville pie plate wheel covers, in preparation for a cross-country trip.
    I also had a trailer hitch and external transmission cooler installed, so I could tow a trailer full of my mother-in-law's stuff from Kansas back to Vegas.
    The car did amazingly well. It got 28 mpg on the way there, and 20 on the way back towing that trailer. I challenge any truck to get 20 mpg towing anything on the highway.
    George continued being awesome. Wagons gonna wag.
    Then in June someone stole the car from my own driveway. I recovered it a week and a half later, with a ruined steering column and ignition.
    Which brings us to today. I went to the junkyard today and got some small things.
    In their infinite wisdom, GM decided that the Century would use a strut to hold the hood up. These invariably fail after a decade, and you end up having to use a pole or ax handle or whatever to hold the hood up. The Cutlass Ciera, however, still used a proper hood prop.
    And it bolts right on to the Century header panel with no fuss, no muss. The Century hood doesn't have a dedicated hole specifically for a hood prop, but there's one that works well enough in the same general area.
    I also snagged this vacuum line.
    It goes from the back of the intake manifold to some tiny little line that ends up controlling the HVAC blend doors. The stock one was in terrible shape, and leaked like crazy. If I accelerated briskly, or had to climb a hill, the air would stop coming out of the front of the dash and instead blow out of the defrost vents.
    Original:
    New one installed. It's just to the right of the alternator and the power steering hard lines.
    Also, at some point, the ABS wiring on the front passenger side ripped itself apart.
    So I got a new wire.
    And put it on.
    Definitely worth the trip.
