Ok, got the engine in, it replaces my 3500 (which still runs fine, I just wanted more power)
Basically an internally stock LZ9 :
60# Mini Siemens injectors
Proform elec. waterpump
TCE timing cover / thermostat outlet
TCE external crank trigger
WOT Tech Street Strip Turbo Cam with pushrods
PAC springs
TCE SBC cam bearing spacers
Durabond SBC cam bearings
75mm GM Truck TB
LZ4 intake manifold (ported)
Pass side mount, was real easy to make, easier than the old 3500 mount it replaced on account of it all being on one plane whereas the 3500 mount had 3 different angles.
Other side is my 3500 mount, so nothing new there, bolts right up...
All kinds of room for my turbo, there's PLENTY of room under the alt. for a 4" downpipe, should I ever require one... 3.5" will do for now :
New Kirkey racing seat, i got the 16" wide Pro Drag with a velour cover. It's very comfy and has all provisions for 5 pt harness, the hole for the submarine strap, ect.
I ordered a bolt in Racecraft mounting braket for it, should be in soon.
And finally I have to re-do some of the charge piping cause I want to run a little bit of 3" before i hit the 75mm LS1 throttle body. Started off by making this 2.5" to 3" cone and will incorporate that somplace into the charge pipes when I get that all figured out.
I ordered a V8 model radiator as my rad hose connections don't work soo well with this 3900. The inlet/outlets on a V8 rad are opposite the V6, left right bottom upper are all criss-crossed so that'll work and be cleaner looking.
Got rid of the power steering :
More to come...
