Last time I was at work, I hung around for a while after my shift ended to browse what the store's system had for my car, and I found that Bullydog apparently makes a full tuning set for my car (trim level and everything) for under $300. With my 20% employee discount, it'll be less than half the price of the HP Tuners one I was looking at.
I also replaced the PCV valve, grommet, bypass hose, and I put some fuel system cleaner in. I usually made about 80 miles on a quarter of the fuel gauge, but this time I made over 100, which seems too drastic for what little I did, so I'll have to check how far it gets in the next quarter.
Until I saw the pictures of the LQ1 oil cooler, I actually thought the only type of oil cooler out there was a small radiator-type one with oil running through where the coolant would normally be. I didn't know there were coolant-based ones.
I'll check to see if my radiator has the extra ports on it tomorrow. Are there any common cars with that bolt-on one? I'll try to find one in a you-pull-it yard.
Originally posted by robertisaar
View Post
