I have converted a couple mutliport engines to carb and hei distributor, i want to put pics up, could someone help me with that????
Multiport coverted to carb!
First off, welcome to the site.
Secondly, looks very interesting! Any reason why you put the carb up on such a raised box instead of closer the the plenum top? Seems like you'd have much better clearances. Will that even clear any kind of hood?
Brad via Tapatalk-Brad-
The box is for throttle clearance, i doubt it would clear the hood with carb flat on the plenum, these setups are for derby cars,(shoulda mentioned that). Although i want to take the next one to the drag strip before i gets smashed cuz these buggers scream!
I also got a pipe dream of using a w body(lumina) subframe with one these setups on a ratrod someday. Probably use a 3100sfi for that though.
lol, this thread made my day.
Why a little 2bbl q-jet? Put a 4bbl 750 q-jet on it and see if it holds together.Last edited by RocketFast321; 12-21-2011, 06:44 PM.EveryDay: 2001 Alero 2.4 5-speed
Hualer, Mpg? ROFL: 1984 Buick Electra Estate Wagon Fresh 3oh7 268h camming. OEM 84 2004r
Originally posted by RocketFast321 View PostWhy a little 2bbl q-jet? Put a 4bbl 750 q-jet on it and see if it holds together.
Trust me the two barrel is plenty and can raunch these motors, specially with no rev limiter
Sappy: how would you go about modifying the lower? Getting something machined? I have often thought about putting old iron heads/ intake on a mpfi engine anyone tried that?
And if anyone considers doing this i would suggest gettin the plenum and lower intake runners steamed out.
