Hey everyone! I've been watching the site for more than a year and finally registered for the forum now that i am getting ready to do some serious mods the the engine itself.
I have an s10 with the 2.8 tbi with 600,000 miles on it, and have parked it due to leaky head gasket, bad clutch release bearing, exhaust leaks due to broken off header bolts that cant be drilled out and leaking water pump with broken off bolts... But i'm getting ready to do a swap for a mpfi 3.4. My old boss is about to get rid of his 94' firebird with the 3.4 or if he doesn't i'll just get one from the junkyard.
SO... here is the big question i have.
if i have the heads machined down, what compression should i run it at? I live in florida so there are no emmisions or inspections of any kind. what octane for what compression ratio? and when will i have to run methanol? is methanol worth the trouble?(i want your opinions) for example could i get away 14:1 with 93 octane? If i did decide to go the methanol route whats the max compression i could run with it?
I was hoping to keep stock pistons with chromoly rings, is that wishful thinking or would i have to get hypereutic or forged? and at what point.
Thanks in advance. -Ben
