Yes, it's on a '7730 ECM running $A1 code. It's driveable but there are so many issues that i felt it was a good time to start over with something designed with wilder engines in mind.
With the 950 i have wideband fueling control, i can scale my own VE and spark tables by load and RPM (up to 10K), it's got knock control, extra inputs and outputs, IAC control and a ton of other things it can do. The software is a little weak compared to Tunerpro, it really needs to be updated but there is so much less to it than GM code that it will be much easier to make it run like i want.
If it was a mild engine in a daily driver i'd keep the 7730 but i'm really running out of patience with $A1.
