My 89 Camaro Project
  • Agreed
    • does it feel faster than the z24? I really wanna see what this thing can do when you get it sorted out
      • It's similar, but it's like apples to oranges.. The camaro hooks up much better than the Z24 did but it's not quite as fun with the auto trans.
        • sounds great once it gets to higher RPM. Tuning has gotta be a bitch with those. Id love to see how the alpha n works on it.
          • ...or a different "LIM". The size of those TB's might need to be closer to the head. Runner length is extremely important on ITB's. There's a few threads at ST about it.
            • That thing sounds bad as hell, I like it!!
              • OK, I was just thinking about it, It seems flow would be increased be a shared intake, since the "mass" of the air is moving constantly in, diverted to each valve as it opens. ITB seems it has no flow until valve opens, then air is pulled in, then when the valve closes, the incoming airstream would in effect hit a brick wall and be reflected back out, causing unwanted turbulence. From what I understand, long intake runners helps low end torque, while short help high rpm power. Is there a way to fabricate a long intake that has a valve to close at higher RPM's to increase power over the entire RPM range?
                I know I am out of my league on this one, but it seems to make sense to me somehow
                • Yes there are variable intake manifolds out there, some factory cars have them, fabricating one would be a pretty big undertaking though. Btw as far as squeezing more power out of that beast, throw some titanium rods at it, electric PS pump if you aren't manual steering, and an electric WP, I think I recall hearing mezierres are good for frequent use. As much as people hype about UDPs you would think there would be more aluminum pulleys, and electric accessories.
                  http://www.cardomain.com/ride/390342...evrolet-camaro
                  • Originally posted by Z3500 View Post
                    The old (mid 90s) Ford Taurus SHO cars had them.
                    • Originally posted by pocket-rocket View Post
                      it has 6 individual butterflies one for each runner. wonder how much work it would take to mod this to work on a 3x00
                      i know that isn't the lower just used it to describe.
                      99 Grand Am GT
                      1357 cam 227 233 .050 dur
                      515 515 lift 112 lsa
                      • Originally posted by geldartb View Post
                        Interesting... You certainly can't beat the price, either.
                        • So, i got bored this morning and cut out a form for a fiberglass old school scoop... Probably won't use it but i thought it might be worth posting for a few laughs...
                          • How are you board?
                            Andy
                            fastest 1/8: 10.19@ 67.17
                            fastest 1/4: 16.16@ 82.70
                            • Looks like a cow bell:P
