My 89 Camaro Project
  • Originally posted by pocket-rocket View Post
    Should have rode the slide out I take it the "cling" noise was a 5 point banging around?
    lol..
    who knows, the hatch is full of parts and the back seat is full of tools.
    • Next video, windows closed.
      • Yep, i'm almost afraid though.. lol
        • sounds awesome and deafening at WOT.
          99 Grand Am GT
          1357 cam 227 233 .050 dur
          515 515 lift 112 lsa
          • Originally posted by Superdave View Post
            At WOT it's loud enough to scramble your brains.
            so is that wiring under the hood lol jk i know you gotta clean it up
            • I drove it around all day Friday and a few more issues came up but i solved a few more as well.
              One of the biggest changes i made was flipping the fuel rail and the ITB's center rail around to hide the fuel and vacuum connections in the back. It also got the fuel lines away from the coil packs which was a fire waiting to happen. I also modified a vacuum ball to act as a buffer for the MAP sensor, we'll see if it cleans up the signal or not.
              i still need to finish plumbing a few things and then put the ITB's back together before i can drive it again. I did fix the throttle cable so now i can finally hit 100% TPS instead of 79% with the pedal to the floor.
              • I would think a vacuum ball would be a little too big of a buffer for the ITB setup and react too slowly. I've read in my performance fuel injection book that you want all TBs reference going to a common "buffer" like deal, but not a very large one due to what I just mentioned- just to get a reading from each cylinder. If I run back across it, I'll scan it and shoot you a copy of that section if you like.
                • That would be cool to see, thanks.
                  It's got a balance plenum already but the volume is extremely small and with having the brake booster and PCV running off of it also it seems like i'm not getting as good of a MAP signal as i could be. It's high enough at idle to throw a code 33 so something is up.
                  I did find that the 3 drivers side ITB's were open a little more than the passenger side, i re-adjusted the idle stops so we'll see if that helps when i get it back together. It's tricky since i'm not using a IAC motor to get the idle right, it's getting closer though...
                  • Ok, I found it, but they didn't address size, but do mention that it cleans up the MAP sensor signal, and they have a pic
                    It's from this book:
                    Performance Fuel Injection Systems HP1557: How to Design, Build, Modify, and Tune EFI and ECU Systems.Covers Components, Sensors, Fuel and Ignition ... Tuning the Stock ECU, Piggyback and Stand [Cramer, Matt, Hoffmann, Jerry] on Amazon.com. *FREE* shipping on qualifying offers. Performance Fuel Injection Systems HP1557: How to Design, Build, Modify, and Tune EFI and ECU Systems.Covers Components, Sensors, Fuel and Ignition ... Tuning the Stock ECU, Piggyback and Stand
Name:	MAP sensor scan.jpg
                    • i smell a safari hydroboost swap comming
                      • Originally posted by bob442 View Post
                        hydroboost brakes are nice. Wish I had them, and I never drove them yet...lol
                          lol..
                          Funny cause I do the same thing. When I work I go until I can't work anymore...which means the tools get a quick load in the car versus back in the garage.
                          I gotta say Dave, you build some really nice work!!! And I mean that.
                          Do you do your own tuning?
                          • I've driven motorhomes on GM chassis with Hydroboost, and it did impress me how well it stopped those heavy pigs.
                            • Yes, Hydroboost is probably going to happen.. Just need 2 people to pay off some debt and i'll start gathering the parts. I also have that rear disc swap to do.
                              Schmieder, Yes i do all my tuning. It's just easier to do it all myself.
                              Right now the car is back up on jack stands for some exhaust modifications, new trans lines and a trans cooler. I might also try to install my Tubular LCA's, aluminum driveshaft and perhaps the 3.73 gears since it's up there.
                              I need to do more idle tuning, since there is basically no idle vacuum the FPR is going up to 55 PSI at idle and drowning the engine in fuel. The oil is pretty fuel contaminated and it's got 3 or 4 fowled plugs right now
                              • You know, one thing I've always wondered about tuning (since I've no practical experience myself) is why not just leave the hose capped for the FPR and set the ECM for 55 psi across the board? I mean, the ECM knows a) how much the injectors flow for a given PSI and b) how much fuel it wants to inject into the engine, so why does it really have to go down on idle when the ECM can just lower the injector pulse? Or is that exactly why? Because then you start to approach too short of an injector pulse where the injector won't completely fire correctly? That's about the only thing I can think of and honestly, it just came to me as I was typing it out thinking of how it works in my head, lol.
