Hello everyone, I've been looking around on the site (amazing might I add) trying to get an idea on how to get my upper plenum off. I have a 95 Z34 monte carlo with a 3.4L. I've removed everything that was stated in previous posts, it seems like it's just stuck. Any advice would be greatly appreciated.
New here, need some help with intake
Did you read step 1 of this article : http://60degreev6.com/content/9697_I...p_9195_Engines ?
If so, and you have it all removed, it is probably just stuck. Use something to gently pry up on it to separate it from the gaskets and lower intake.
And welcome to the site!-Brad-
Hi there & Welcome....are you absolutely sure you've removed ALL of the fasteners holding down the plenum?...when you say *it's stuck* do you mean it will not move at all?....There are 7 bolts that can be seen from the top & there are 2 more at the back that are out of sight, but those 2 are on rubber supports and should not *freeze* the plenum into place. Read thru this and go over what you've done to see if you've missed something.Last edited by 55trucker; 02-01-2009, 07:04 PM.91 LQ1 GP GT
Let me first say WOW! This forum kicks a@#! Secondly, i've removed everything stated in the books description. When I said stuck, i meant that it is not moving at all. I've looked over everything and even tried to gently pry up on it and it still won't budge.
Finally, got if off after coming home today. I put a crowbar inbetween the bottom of the plenum on the passenger side and used the engine hook thing as a lever. It was on there pretty good, but after wrestling with it for a couple minutes, it finally gave way. Thank you guys so much for the help. I'll definitely be a regular on here now.
Glad you got it off.....you are not the 1st to have this same problem...from my own personal experience (mine has been off twice now and came up freely) the plenum is not supposed to be adhered to the manifold in any way, unless someone sometime in the past has had it off and used a glue product to seal it down. At least now you can get your work done.91 LQ1 GP GT
Originally posted by 55trucker View PostGlad you got it off.....you are not the 1st to have this same problem...from my own personal experience (mine has been off twice now and came up freely) the plenum is not supposed to be adhered to the manifold in any way, unless someone sometime in the past has had it off and used a glue product to seal it down. At least now you can get your work done.
