96 Beretta Project
  • rodney better post up some times and you ol man ought to talk to him bout coming to the mini meet as many of us would like to see this car also
    and IMHO if i had the money i wouldve loved to have bought johnnymossville setup high CR w/ cam headers and a 5spd lsd would be sick
    • Originally posted by asylummotorsports View Post
      If you are going to wander from N/A then IMHO, and from what I have seen, Nitrous is not the way to go.
      I KNOW of a couple of 3400 Cavys with Turbos on stock engines on the J-Body Forums that are well into the 12's, and these are kids who don't know what the hell they are doing!!
      (Really! Mars can confirm this!)
      And there may be more news tonight. Rodney was heading to TMP tonight with his 3500 turbo/intercooled 5-speed that just may shock some folks.
      FWIW!
      It all comes down to I have the parts to continue to work with Nitrous right now... Am I going to stay there forever, Probably not.
      And what do you mean wander away from N/A, How many times do I have to tell you I never intended this motor to EVER run N/A except on the street... I only did that at the strip to satisfy you since you kept bugging me about it.
      Right now any direction I go in it all means LOTS of money to revamp the motor since none of the directions are geared toward what I have. N/A means a new cam, higher compression and so on... Turbo means all the turbo parts and pipe and so on.
      I'm leaving it as is for now, I've made that decision and all I'm doing this winter is going through the trans and also inspecting motor components for any odd wear. If I have the time and can afford a set of head gaskets, maybe I'll port the shit out of it.
      Also who says I can't just do a larger nitrous shot.... if you think about it those turbo's in the 12's are producing that much extra HP in just a different way. People always forget all that nitrous is doing is inducing more air/compression into your cylinders JUST like a turbo or supercharger, its just done in a different way.
      BTW, Can this topic title be changed to "96 Beretta Project" Rather than the gloating title that well really doesn't apply with my whopping 14.8 1/4 mile times now... LOL
      • If you go big shot with nitrous, I'd go direct port or have some way when you engage the gas, the injectors squirt the extra fuel needed at that time. Should be safer in case fuel is puddling in the intake plenum somewhere or some cylinders run leaner than others due to this.
        • Thank you mods... And yeah if I go bigger it will be a DP system... Somehow I'll make it fit
          • One more Lope before Hybernation... I brought the idle down to 730-800 rpm... Any lower and I think it wont even run... LOL
            Oh and you can't help but notice the nice healthy dose of piston slap... LOL One major reason why I'm pulling it apart this winter, its not as loud in person as on the video but its still there and I want to make sure that my pistons are not all scratched up or wrecking my block. This sucker does have a bit over 30k on the bottom end now.
            Winter plans, the first upgrade on the list is really a downgrade... Going by weights I found, I'm going back to what I originally planned to run for brakes. I'm swapping out the F-body stuff for a set of N-body equipment. I have the calipers pads and rotors now. I'm look at a total rotating weight loss of 12-14lbs just by changing the rotors. Beretta's are 11.4, Grand Am are 13.5 and the Camaro ones are 19+ I think I can live with the 11" brakes for now.
            The other things on the list are a few engine tweaks... I'm going to tear into it and see how things are going inside and inspect cylinder bore's and bearings and such, and then move on to the heads and give those full porting treatment... When I built this motor back in 07 IIRC for ole red I only did gasket matching for the lower to the head, and upper to the lower... I never continued the port smoothing throughout the runners. So I'm sure if I clean up the heads and intakes I can gain a few pony's
            After that the trans is also getting a look to see if there are any worn parts, and then I'm changing out all the valves and such in the VB for the anodized ones that wont side load as easy, hopefully that will firm up my 2-3 shift some since that still seems to be quite soft. LSD will also get checked and maybe shimmed up a bit to provide more pre-load, I think the clutches should be fine in it but they are 2yrs old at least now so its worth a check.
            So all and all a good amount of upcoming upgrades/downgrades to keep me busy this winter... Hopefully they all go smooth and I get the car closer to its 13 sec n/a time it once ran...
            • I doubt the pistons are messing up the block, but it will be interesting to see. Mine knock but goes away once warmed up. Has for YEARS. I don't care I just put it in gear and drop the hammer... LOL. The thing doesn't use ANY oil just drips a little from the oil pan, but you don't get drips on the ground unless the car is parked in one spot for like 2 weeks. The 3100 in my car just won't give up.
              Does your piston slap go away once warmed up?
              • Yeah as much as any other car does...
                But I've see what it can do if its to the extreme... Luckily IIRC the 05 pistons are skirted with teflon... but I may be wrong. Either way I don't want the cylinder bores to get scored because if I ever plan on doing pistons the less machine work the better. If I can get away with just a hone in the future that would make me happier.
                I will also probably be doing SBC cam bearings while I'm in there.. now that I know they fit.
                • Originally posted by IsaacHayes View Post
                  The slap can be nothing to worry about for standard cr N/A engines, you add boost, more cr or nitrous and all bets are off.
                  Sounds good.
                  • January 2010 progress so far... Worked on it Wednesday.
                    Pulling trans next weekend OR Monday the 18th... then getting motor out.
                    I hope the inside of the trans is a direct reflection of how red the fluid still was, I was quite impressed with how clean it was, so hopefully that's a good sign.
                    I was also pleased with my woodstove install... I got home around 3:30 or 4 and started it, and I was out there at around 4:30, obviously then it was still chilly, but by 5:30 it was quite comfortable to work in there... My hands weren't cold and if I did get a chill I could just walk over and warm up easily. But by 6 it was significantly warmer in there than it was outside... So I figure if I go to work out there on the weekend if I fire off the stove at 6 in the morning come in, do stuff around the house, eat something and then go out the garage will be quite comfortable...
                    And to get this result wit still no insulation at all I'm impressed and happy. I can't wait till I insulate it.
                    • that is one nice garage! i'm so envious.
                      Andy
                      fastest 1/8: 10.19@ 67.17
                      fastest 1/4: 16.16@ 82.70
                      • Made some progress yesterday.
                        Pics
                        Took longer than I wanted to get the drive line out but I was also screwing around with my stove and stuff.
                        Time to get my engine stand to the house so I can start working on the motor now.
                        • So, Dave... Did you replace your pistons when you found this?
                          Effin stretched timing chain must be the cause of this since the marks are nice and coated with carbon so it wasn't a recent hit. Could have easily been one from 2008 when I ran my 13.996 with that stretched bioch and was hitting 6750 rpm over and over again... LOL
                          Valves also have no marking on them right now, they have a nice tan color to them.
                          • Nope, i left mine in. they're now "Pre-clearanced"
                            I plan on getting a cutter for the exhaust side and cutting another .020-.040 into it though.
                            what's the exhaust duration on your cam?
                            • Originally posted by Superdave View Post
                              240 @ .050", methinks.
                              Matt
                              • Dave, I thought you swapped pistons once??
